[FONT=Arial, Helvetica, sans-serif]NGKPFR6T-10G[/FONT] | | [FONT=Arial, Helvetica, sans-serif]B207E / B207L .9-1.0mm 9-3 SS [/FONT] |
[TD="width: 155"][FONT=Arial, Helvetica, sans-serif]NGKBCP
R
7ES[/FONT][/TD]
[TD="width: 87"][FONT=Arial, Helvetica, sans-serif]91 12 541[/FONT][/TD]
[TD="width: 611"][FONT=Arial, Helvetica, sans-serif]900 B204 TURBO (94-98)
9000 B202 TURBO with DI
9000 B234 TURBO
9-3 B204 TURBO 185 HP (1999)
TUNED
B207L / B207R .9-1.0mm 9-3 SS
B205R 9-3/9-5
B235R 9-3/9-5[/FONT]
[/TD]
[TD="width: 155"][FONT=Arial, Helvetica, sans-serif]NGK BC
R
8ES[/FONT][/TD]
[TD="width: 87"] [/TD]
[TD="width: 611"][FONT=Arial, Helvetica, sans-serif]Very High output cars. Gap 1.0-.9mm[/FONT][/TD]
R
6ES - 11[/FONT][/TD]
[TD="width: 87"][FONT=Arial, Helvetica, sans-serif]91 17 565[/FONT][/TD]
[TD="width: 611"][FONT=Arial, Helvetica, sans-serif]9000 B234 Nat. Asp. with DI
9-5 B235 TURBO[/FONT][/TD]
[TD="width: 155"][FONT=Arial, Helvetica, sans-serif]NGKBK
R
7ES -11[/FONT][/TD]
[TD="width: 87"][FONT=Arial, Helvetica, sans-serif]91 71 307[/FONT][/TD]
[TD="width: 611"][FONT=Arial, Helvetica, sans-serif]9-5 B308 V6[/FONT][/TD]
[TD="width: 155"][FONT=Arial, Helvetica, sans-serif]NGKPF
R
7H - 10[/FONT][/TD]
[TD="width: 87"][FONT=Arial, Helvetica, sans-serif]91 88 681[/FONT][/TD]
[TD="width: 611"][FONT=Arial, Helvetica, sans-serif]Discontinued > Use NGKPF
R
6H - 10
Hard Use only. Prone to cold fouling on short trips.
[/FONT][FONT=Arial, Helvetica, sans-serif](HOT T7 cars)
9-3 B205 TURBO 185 HP (2000>)
9-3 B205 TURBO 205 HP
9-3 B235 TURBO 230 HP VIGGEN
9-5 B235 TURBO AERO[/FONT]
[/TD]
R
6H - 10[/FONT][/TD]
[TD="width: 87"][FONT=Arial, Helvetica, sans-serif]93 99 866[/FONT][/TD]
[TD="width: 611"][FONT=Arial, Helvetica, sans-serif]9-3 B204 TURBO 200 HP (1999)[/FONT]
[FONT=Arial, Helvetica, sans-serif]9-3 B205 TURBO 185 HP (2000>)
9-5 B235 TURBO AERO [/FONT]
[/TD]
[TD="width: 87"]
[FONT=Arial, Helvetica, sans-serif]*NOTE[/FONT]
[/TD]
"7"
series spark plugs have a colder heat range than
"6"
series and are, therefore, commonly used as an alternative plug on cars consistently run at high speeds or under heavy loads. Running too cold of plug for short trips will lead to fouling. This is more of a problem in the winter.
"R"
in the NGK plug designation signifies resistor type this is very important. [/FONT]
"P"
in the NGK plug designation signifies Platinum electrodes. These are more expensive but last a bit longer. It is ok to run copper "C" plugs in the application that originaly had platinums as a cost savings but they will requre more frequent sevice. [/FONT]
[/TD]
