Alle Beiträge von Nordischbynature
Personal Options programmieren lassen im Raum Schleswig-Holstein
Folgendes habe ich bei motor-talk gefunden: (nicht schlagen, ist ne Menge Holz und ja, ich hätte es verlinken können, wenn das Tablet nicht so rumspinnen würde:eek:) 9-3 SS Programming Options / TECH-II & SID Profiler SID Profiler Adjustments (User Programmable) ============================================ * Rain Sensor: -------------- Desc.: Rain Sensor Sensitivity of Rain Sensor can be adjusted Settings: Rain Sensor High: The wipers will operate when there is a small amount of rain on windscreen. Rain Sensor Medium: Default Setting of Rain Sensor Rain Sensor Low: Wipers will operate when there is a greater amount of rain on the windscreen as compared to High & Medium settings. * Theft Alarm: -------------- Desc.: Theft Alarm Settings/Trigger settings Settings: Full Theft Alarm: Default Setting Provides full theft alarm security. including Interior Movement, Vehicle Tilt, Door/Bonnet/Boot opening detection. Door Alarm Only: Enables customer to select Door Alarm activation only when pet is in the vehicle, vehicle transported on a ferry, or during adverse weather conditions which may trigger alarm.. * Climate Control: ------------------ - Rear Defroster Settings: Auto: Default Setting that provides automatic selection of Rear Window and Door Mirror demist, based on ambient temperature. Manual: To activate Defroster, Driver will need to press the Rear Window Defrost Button - Heated Seats Settings: Auto: Seat Heating will be switched on automatically when the ambient temperature is below 15o c and the seat temperature is below 20° c (defaults to temperature level 2, driver can adjust to level 1or 3 which will be saved) Manual: Default Setting. The Driver presses the Seat Heating switch and adjusts the seat heating to the required Temperature Setting 3= approx 56° C Setting 2 = 46°C Setting 1= 39°C - Fan Setting High Speed Settings: Medium Speed: Default Setting ACC will adjust the fan speed according to the conditions. Low Speed: ACC will adjust the Fan Speed according to the conditions, however, Fan speed will be slightly lower than if fan speed High or Medium was selected. High Speed: ACC will adjust the fan speed according to the conditions however, this setting will provide the driver with slightly higher fan speeds than Medium & Low - Air Distribution Auto Settings: Auto : Default Setting. Automatically directs the Air Outlet to the Windscreen, Air Vents Face or Floor dependant on ambient temperature and setting. Manual: Provides the Driver with the option of selecting the appropriate Air Outlet - AC Mode Auto Settings: AC Auto: Default Setting Automatic engagement and disengagement of Air Conditioning Compressor. AC Off: Turns the Air Conditioning Compressor off to save Fuel. In this mode no cooling or dehumidifying is available and the windscreen may fog up. Pressing the Auto or AC button (above 5°C) will reactivate compressor. However, the AC compressor will be remain off the next time the vehicle is started. - Dual Single Zone Settings: Dual Zone : Default Setting Provides for the setting of individual temperatures between Driver & Passenger zones. Single Zone: Adjustment of the Driver's temperature will also adjust the passenger's temperature, however if the passenger temperature is altered the system will revert to Dual zone until the vehicle is switched off. On restarting the vehicle, single zone will result. - Climate Control Default Setting Settings: Yes / No: Allows the driver to quickly reset all adjusted ACC parameters to the original default settings * System Settings ----------------- - Language Settings: Desired language of the SId and the Infotainment System - Units Settings: km/h or mph - Speed Scale illumination Settings: In nightpanel mode illuminate 0-140 km/h or 0-260 km/h - Service Information Select Appropriate Language Settings: Service Data detailing Oil Quality and Time for Service can be viewed. Tech 2 Adjustments: (NOT User Programmable) ===================================================== * Panic Alarm ------------- Desc.: Disablees or Enables the Panic Alarm via remote control * Trunk Unlock -------------- Desc.: What happens when the trunk button on the remote is triggered Settings: Single Press Unlock+Open: Single press of the remote or door switch will unlock and open boot Single Press unlock / Double Press Open: Single press of the remote or door switch will unlock; double press will unlock and open boot. * Trunk Lock After Closing -------------------------- Desc.: What happens to the trunk lock when closing it. Settings: Yes: Automatically lock Boot on closing No: Boot can be reopened using micro switch button located on the trunk/boot * Trunk Lock After Drive Off ---------------------------- Desc.: Should the trunk be locked at drive off or after 30 sec.? Settings: Yes: Trunk/Boot will automatically lock when vehicle increases speed No: Trunk/Boot will remain closed, however will be in the unlocked condition if No was selected in the previous option. * Door & Trunk Unlock at Key Out -------------------------------- Desc.: When the is removed from the center console should door/trunk be unlocked? Settings: Yes: All Doors & Trunk/Boot will Unlock when the Key is removed from the Ignition Switch If Driver frequently locked all Doors when driving this feature would be beneficial. No: Doors and Boot will remain in the same condition as they were prior to Key removal * TSL Locking Logic (Theft Security Locking/Deadlock) ------------------- Settings: TSL at first Press: Default Setting. All Doors will lock in Deadlock Mode TSL at Second Press: All Doors will lock in Deadlock mode at the second press of the Remote. * Lock /Unlock Acknowledge -------------------------- Settings: None : No acknowledge will be visible Indicators: Indicators will blink as acknowledge * Follow Me Home Function ------------------------- Settings: Tail Light: When selected Tail Lights will be illuminated Back Up Light: When Selected Reverse Light will be activated Tech 2 Body Exterior Lighting & Horn ==================================== * High Beam Follow me home Active Time -------------------------------------- Desc.: Follow Me Home Active Time can be adjusted between 0- 10 minutes Settings: This Feature can be turned on or Off .Yes / No can be selected. Low Beam Automatic / Low Beam also in Position 0 (light switch) Yes / No Follow Me Home Active Time - Daytime Driving Lights can be activated * Parking Lights ---------------- Settings: Act as Lead Me To the Car Light. * Park Light On Reminder ------------------------ Settings: On / Off If Ignition is turned Off and the parking lights are active, Driver will be warned if set to on. * Show Trailer Light Outage Desc.: REC will detect blown trailer light and display on SID Settings: Yes or No * Trailer Light / Fog Light off ------------------------------- Settings: Yes: Fog Light Rear will be disabled When Trailer is connected Yes No * Horn Lock Unlock Acknowledge ------------------------------ Settings: On: Horn will honk when car is locked Off: Horn will not honk if car is locked Tech 2 Body Locking =================== * Panic Alarm Activation (Vehicles fitted with /Alarm only) ----------------------------------------------------------- - Panic Button / Locking Switch Central Locking Switch Driver /Passenger Settings: - Panic Button on Remote and locking switch inside vehicle will activate alarm - Panic Button will activate Alarm only - Locking Switch inside vehicle (driver /passenger will activate alarm only - No Panic Alarm function required. * Unlock Logic -------------- Settings: All at first press : All Doors will open & Fuel Lid will unlock if the Driver or Passenger Door Switch is activated Driver Door & Fuel Lid at first press : Only the drivers Door will unlock & Fuel Lid will unlock when door switch is activated * Remote unlocking One Press ---------------------------- Settings: All at first press: All Doors will open & Fuel Lid will unlock if the Remote is pressed Driver door & Fuel Lid at first press: Only the drivers Door will unlock & Fuel Lid will unlock when the Remote is pressed Tech 2 Body Front Wipers &Washers ================================= * Additional Wipes ------------------ Desc.: Below this Vehicle Speed Adjustment / Used after washing the windscreen. System will activate an additional wipe to remove excess water run off. Therefore Driver can wash screen without turning wiper on to wipe runoff. The Vehicle Speed at which the additional wipe feature cancels can be set. Number of Wipes after wash Number of Wipes after wash is programmable. The number of wipes can be set between 0-10. Settings: Wiper/Extra Wipe Enable: Yes: Extra Wipe enabled No: Extra Wipe not enabled Front Washer: Number of Wipes after wash Number of wipes can be set between 0-10 Recirculation for 30 seconds after wash * Bi Xenon Only Washer activation time -------------------------------------- Settings: Yes / No * Washer activation 1 --------------------- Reduces or increases the amount of washer solution dependant on driving conditions Washer activation time for the first wash can be set between .1-2.0 seconds * Washer activation 2 --------------------- Desc.: Reduces alcohol smell during windscreen washing. Settings: Yes: Recirculation activated to reduce washer solution alcohol smell (AC/ACC recirculation) No: No Recirculation during windscreen wash Washer activation time for the second wash can be set between .1-2.0 seconds * Headlight Washer Blocking Time (Bi Xenon only) -------------------------------- Desc.: Headlight Washer Blocking Time; Determines the time required before an additional headlight wash will be performed Settings: Default setting is 2 minutes. Driving conditions may dictate less or more time before a subsequent wash is actioned. Adjustment between 0 seconds-infinity. Tech 2 Body Heating & Ventilation ================================= * Air Distribution Floor Mist Delay at Start Up ----------------------------------------------- - Open Defrost in Hot Climate: Yes /No Delays the Air Distribution to the screen on start up to reduce fogging the inside of the screen. Select yes to allow air to be directed to screen during AC cooling operation. Select No if Screen is fogging up on the outside of the screen during AC operation and high humidity. Air Flow Fan Mist delay at Start Up 0-30sec. - Recirculation Semi Auto Yes /No Recirculation Manual Yes / No Recirculation After Wash 30seconds Yes /No Delays fan operation for selected time to reduce screen fog up ACC will control recirculation, can be overridden by manual selection, however, will revert to Automatic on start up. Recirculation or Fresh will be Manually selected and maintained on next start. Alcohol smell from washer fluid is reduced. - Rear Demist Rear Demist Activation Time 5min - 20minutes Tech 2 Body Theft Protection ============================ - Drivers Door Doors & Trunk will unlock at key out - Door Lock if not opened. - Door Switches Unlock Function Yes/No Door will automatically lock if unlocked and not opened. These are the same adjustment items as unlock logic. Passenger Door Same as Drivers Doors Adjustment items Rear Left Door Same as Drivers Doors Adjustment items Rear Right Door Same as Drivers Doors Adjustment items
15 Minuten vor 06:00 Uhr
Zwei "Ersatzteile" hättest du dann aber schon mal
"wir" haben uns verstanden... (da hatte wohl die Rächtschreibkorrektur ein Eigenleben) Peer war auch "hier"-er kam aus Bochum... Edit Den Peer hatte ich wirklich nicht auf dem Schirm. Das Wortspiel hat aber was...
Neee. Die haben nur ein paar "Problembären" dagelassen:biggrin:
Autobahnvignette
Ich hätte meine Ironie wohl etwas kenntlicher machen müssen...
Das gehört dazu: vertreibt die wilden Tiere wenn das Lagerfeuer runtergebrannt ist
Tagfahrlicht
Moinmoin Dirk. Ganz ehrlich gefällt mir die Variante 1 am Besten: sie fügt sich nahtlos in die Optik ein und stört nicht den designerischen Auftritt des Fahrzeugs ein. Wirkt auch wie "dazugehörig" und nicht "aufgesetzt". Wie sollen sie geschaltet werden? Gruessings Jörg
Neeeee.....bin noch da... Guten Morgen.
Eher jemand *bereitschaftausdembettklingler* Jetzt geht' zur "richtigen" Arbeit
Guten Morgen...
Autobahnvignette
...wer war noch mal gleich Auftraggeber der Studie?
Urlaub 2013 - wo geht es hin, darf der SAAB mit?
DIE Idee hatte ich auch mal. Daher kenne ich die Ecke. Viel Spaß
Hi. Wenn dich ein paar Motorradfahrer nicht stören: http://www.reipertingerhof.com/de/home.php Wunderbare Ecke...
Geburtstag Erik Carlsson
- Autobahnvignette
Ach so.... Es wird etwas in das "System" eingezahlt, und es wird umgeschichtet um es dann einem Zweck zuzuführen. Klar das so keine Zweckgebundenheit zustande kommt. Doch ein Mindestmaß an gut funktionierender Infrastruktur muss geben. Wenn jemand auf dem Weg zur Arbeit (oder bei der Arbeit) im Stau steht, kostet es die Volkswirtschaft, da es eine unproduktive Zeit ist. Wo hat die Studie die Grenzen gezogen? Solange real noch damit Geld verdient wird, dass Humankapital untätig auf den Strassen stehen muss, scheint der Leidensdruck noch nicht hoch genug zu sein, etwas zu verbessern. Auch das ist Volkswirtschaft. Ich bin es nur so langsam leid, mir von jeder Seite in Tasche greifen zu lassen. Eine neue Umlage/Steuer trägt nicht gerade zu meinem Wohlbefinden bei. Denn dann rege ich mich auf, bekomme einen Herzkasper (nicht zu verwechseln mit lebenden Personen) und falle anschließend der Volkswirtschaft zur Last... Kann mich jemand verstehen?- Autobahnvignette
Ich weiß, ich wiederhole mich: bräuchten täten wir eine Maut nicht, wenn die Gelder zweckgebunden verwendet würden. Doch bei den ganzen Umverteilungen würden wieder neue Löcher gesucht werden, in dem man die Mauteinnahmen versenken kann. Würde sich etwas ändern? KFZ Steuer weg? Mineralölsteuer kleiner? Wohl kaum. Die Sektsteuer gibt es ja auch noch, obwohl Kaisers Flotte auf dem Grund der Nordsee liegt. Maut wegen Gleichbehandlung "ausländischer" Benutzer der Autobahn? Ohne eine Maut für Inländer? Mit der EU nicht machbar. Und es kommt eh, wie hier einige sich schon geäußert haben: erst mal sehen, wie weit man gehen kann und dann noch etwas weiter drüber gehen. Der Michel wird sich schon damit arrangieren... (Hat er ja bislang immer) So... Jetzt geht's mir wieder besser ::- 15 Minuten vor 06:00 Uhr
Guten Morgen...- Seit heute glücklicher Saab-Besitzer
Das du das alles hinbekommst habe ich auch nicht ernsthaft bezweifelt. Mit Zeit und Durchhaltevermögen ist Alles machbar.- Seit heute glücklicher Saab-Besitzer
DAS habe ich mir auch gedacht. Genug Enthusiasmus scheint vorhanden zu sein. Halt durch!- Autobahnvignette
Ein Schelm, wer da Willkür vermutet: alles wohlfeil kalkuliert...- 15 Minuten vor 06:00 Uhr
Wenn du Äktschn brauchst, dann kommt deine Asche in 'ne Eieruhr:biggrin:- Autobahnvignette
Aber dafür wird es ja auch eine 2-Monatsvignette geben und dann einige Jahre später 390km neue, schweizerische Strasse. Ja: die Eiggenossen wollen die 300MioCHF zweckgebunden verwenden. Solange das hier in D nicht geschieht, brauchen wir kein Pickerl.- Seit heute glücklicher Saab-Besitzer
Hi Hier gibt es einen Mega-Fred: http://www.saab-cars.de/attachments/900-ii-9-3-i/45107d1268691358-verdeckhydraulik-900ii-verdeckmechanismus1-20090222223028.pdf Hoffentlich ist das Passende für dich dabei...- 15 Minuten vor 06:00 Uhr
Auch einen guten Morgen...- Halbjährige Batterie nach 6x Anlassen leer
Stimmt; ganz meiner Meinung. Aber ich wollte keine Werbung schalten... - Autobahnvignette
